I am trying to make something like a pyramid corner to fill up the gap (As shown on the right) but extending the extrusions to cut doesn't seem to work. Is there any solutions for this?
Solved by jay_colcombe. Go to Solution.
do you model all the element and void in same model in place ?
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
The best way i can see this working is creating a rectangle for the corner and then 2 angled void extrusion following the original shape edges so they can be used if the shape adjust to cut from this to create the pyramid shape
Why don't you make the main piece bigger and use void to cut off 3 sides?
