I have just installed RISA 3D v18. Revit exports to RISA v17.4 however. What can be done to adjust that?
Also, I have attempted to Install Robot 2020, but it does not run. What can be done to correct this. It installed correctly (I think) but it does not start.
How are you exporting to RISA? There is a special link that you need to have to get your Revit model to "talk" with the RISA model. Risa to Revit
I frobot does not run I would recommend doing a repair install or completely remove and reinstall it. Please post any error messages that you might get from that to help
We use the Risa Revit link add on for Revit and it works really well. I know we had some trouble with the steel member names between Revit and Risa, and just making sure you use the same naming in Revit that Risa uses. If you have specific problems please post here or DM me directly.
Hello, when I want to import Risa 3D into Revit using add-on tool, this message appears "Project information has been disabled in Revit. Can not import/export" and I do not know what it exactly means.
How can I solve it?
Thanks!!
