Hi there,
I would like to know if there is a way to map the Revit model analytical section to the Robot Database without using the Family Type Name.
I think it worked in previous versions by using the Section Name Key parameter, but it doesn't seem to work with version 2024.
If the Family Type Name is different from the Robot Database, even if the Section Name Key is the same, Robot doesn't recognise it and creates a Parametric Section taking the dimensions, but not the Standard Sections.
Please find attached an example image:
![RobotSectionName.JPG RobotSectionName.JPG](https://forums.autodesk.com/t5/image/serverpage/image-id/1335724i38AB710AA2409AA8/image-dimensions/432x329?v=v2)
![RobotParametricSection.JPG RobotParametricSection.JPG](https://forums.autodesk.com/t5/image/serverpage/image-id/1335725i4C79901AC39D3217/image-size/medium?v=v2&px=400)
Thank you in advance,
Maria
