Reinforcement Code Check (Robot Structural Analysis app)
1900820269
Message 1 of 12
1900820269
Hello, Thank u all for the help u provide.
I would like to know if, when a project is modelled in Revit and analyzed in Robot structural Analysis, is there a way u can transfer designed reinforcement from Robot Structural analysis to Revit structural. Am using V2024.
Secondly,
if the results are imported in Revit, is there a way i can display these results and also be able to use them directly inside revit .?
Thank you, any help rendered i will r greatly grateful.
Replies (11)
Message 2 of 12
Ahmed_Muharram
Hi
check below links
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Is-it-possible-to-...
https://help.autodesk.com/view/RSAPRO/2023/ENU/?guid=Robot_GSG_Getting_Started_Guide_Send_a_Model_to...
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 12
umut.akparlar
You cannot transfer reinforcement from robot 2024 to revit 2024. Autodesk removed that feature from 2022. You can transfer reinformcenet from robot 2022 to revit 2022 for certain members not all of them.
Message 4 of 12
jay_colcombe
I can only assume you can export a Revit model into Robot for Analysis and then bring the Results and information back into Revit if changes have been made etc.
Then from Revit you can select specific Elements and use the reinforcement Code Check which takes the element back into Robot and Allows you to design it on the analysis information that is associated from the initial Revit-Robot integration.
Jay Colcombe
Autodesk Certified Instructor
Message 5 of 12
umut.akparlar
There is no reinforcement Code Check for Revit 2024. Are you talking about third party add ins? And there is no reinforcement transfer between robot and revit 2024.
Message 6 of 12
Ahmed_Muharram
It's available
Message 7 of 12
umut.akparlar
Interesting, I haven't got that option. I saw that option with previous versions of revit but still there is no reinforcement transfer between revit and robot 2024 ? At least I cannot do it like on the robot 2022.
Message 8 of 12
jay_colcombe
You could try uninstalling the Revit Structural Analysis Addin for 2024 and reinstalling?
Also is it related to Robot 2024 alongside Revit 2024 being installed as there may be a anomaly with different versions of Revit and Robot? (It may not like the Code Check due to newer features in Revit 2024 vs 2023)
Jay Colcombe
Message 9 of 12
1900820269
thank you,
but the elements, when back in robot analysis, for design , they seem to lack the analysis  information, the loads table is empty and prompts to be filled ...could u share your process please that can tranfer the analysis information back to robot for Rc element design, highly appreciate it.
Message 10 of 12
1900820269
Thank you,
Although this doesn't seem to work for Revit v2024
Message 11 of 12
victor_vijeuKD42L
@1900820269 : You can import rebar cages from Graitec Advance Design into Revit, if you must import rebars.
https://graitec.com/uk/resources/expert-content/bim/structural-bim-workflow/
Revit Structure Certified Professional
Revit Architecture Certified Professional
Autocad Certified Professional
Message 12 of 12
1900820269
ROBOT STRUCTURAL ANALYSIS XREVIT WORKFLOW  kindly
