Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Embedded beams
1 REPLY 1
472 Views, 1 Reply
Embedded beams
Hi everybody,
Sometimes I have beams that are embedded in walls. I would like that those beams were represented with a fill pattern. The problem is that due to the fact that the beams are behind the walls we cannot see it. I figured out four possible solutions.
  • Fill patterns regions: Current “sloppy” solution.
  • Plan region: Unmanageable.
  • Structural framing with an invisible vertical model line and a nested fill pattern. The problem is the beam fill pattern masks the wall pattern.
  • Wall transparency. In some cases, wall fill patterns disappear but I don’t know why.
Any other ideas?
Thank you in advance.
vigas embebidas 1.JPGvigas embebidas 2.JPGvigas embebidas 3.JPGvigas embebidas 4.JPG
1 REPLY 1
cbcarch
How about a Structural Framing Plan, with an Underlay showing the walls?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Forma Design Contest
