Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Doesn't work Split Element
4 REPLIES 4
ArmanMargaryan
1395 Views, 4 Replies
Can you say me what the problem is? Please watch the attached video.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Labels (2)
4 REPLIES 4
Jamhmer_Oc
in reply to: ArmanMargaryan
Hi @ArmanMargaryan
When you insert a connection to the column, the element properties change to a "Steel Fabrication Shape"
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
Once the item has been converted to a form of steel fabrication, some Revit tools can no longer be applied.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
You must first split and then apply the connection, just like you did in the beginning.
Perhaps in future versions, it will be possible to apply these tools even with the connections.
Jamhmer Oc
ArmanMargaryan
in reply to: Jamhmer_Oc
Thank you very much.
Arman Margaryan
Linkedin | Facebook
AK_souilmi
AK_souilmi
thank you very much for you answer, but this is deeply disappointing, being able to split and element with connections should be easily done, same thing for creating connections for double angles(many trusses are made by connected double angles), these are very frequently used operations. When using Tekla, I didn't image those kind of issues could exist. I can't see how the great Autodesk didn't address those basic issues. very disappointing .
Forma Design Contest
