Can you say me what the problem is? Please watch the attached video.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Link copied
Arman Margaryan
When you insert a connection to the column, the element properties change to a "Steel Fabrication Shape"
Once the item has been converted to a form of steel fabrication, some Revit tools can no longer be applied.
You must first split and then apply the connection, just like you did in the beginning.
Perhaps in future versions, it will be possible to apply these tools even with the connections.
Jamhmer Oc
Thank you very much.
Arman Margaryan
