Demolished walls not showing dashed in linked model
RobDBrown
Message 1 of 12
RobDBrown
I have a linked Revit model with correctly mapped phases and graphic overrides set for demolished work. The demolished walls in the linked model shown up in the correct colour override (orange) but not the correct line style override (dashed) ? Walls created in my model show with both correct colour and line style overrides.PHASES.JPG
Replies (11)
Message 2 of 12
Ahmed_Muharram
check that there is no lines on the same position
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 12
MostafaElashmawy
You need to make sure that your linked file is linked the host view display settings.
from VV>> revit links>> in front of linked file select by host view.
Mostafa Elashmawy
Message 4 of 12
hmunsell
Check your Phase Filter and Overrides settings
  • Manage ribbon > Phases > Graphics Overrides
    • make sure phase filters including"Demo" have the demolished category set to so Overridden
    • make sure demolished is set to show dashed in the overrides
Check your Link to make sure your "Phase From Link" is set properly
  • select your link
  • Edit type
  • Phase Mappings
And of course make sure your Phase Filter in your view is set to Demo +New or Previous +Demo
Howard Munsell
Message 5 of 12
RobDBrown
This is set correctly but still solid lines ?
Message 6 of 12
RobDBrown
Phases etc all set correctly but still solid lines ?
Message 7 of 12
Ahmed_Muharram
could you share the files
Message 8 of 12
christina.bennett
I am currently having the same issue. It has to be in the host model for me because we have other host models with the same linked settings.
Message 9 of 12
christina.bennett
And the other host models are showing the demo walls correctly.
Message 10 of 12
Scott.MacKenzie
Try different line patterns for Demolished elements in the Phases Graphic Overrides setup.  A line pattern that is too tight may not work with the linked model, but will work with elements in your (host) model.  In my case, I set the line pattern to Demolished and it resolved the issue.
Scott MacKenzie, AIA Assoc.
BIM Manager
Stantec Architecture
50 West 23rd Street 8th Floor New York NY 10010-5272
scott.mackenzie@stantec.com
Message 11 of 12
BIM-CONG
There are two settings need to be checked:
1. VV-->Revit links;
2.Phase Mapping;
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
- BIM THE FUTURE -
Message 12 of 12
eric.warnagiris
If the phase settings don't also exist in the linked model, they will not display properly.  Make sure you have the same Phase settings in all models.
