Define one element in a Rebar Set
Is there a way to modify one of the rebars in a rebar set (or area reinforcement) independently from the set?
Lets say I used area reiforcement for my slab. Where I have a column, one of the slab bars clashes with the column bar and I want to move that specific one around. Is that possible?
If not, what would be the workaround it?
Thank you!
Ahmed_Muharram
select the area reinforcement and click on remove area system but you will not be able to group them again
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Thank you for the response, this way you can change the whole set but still not the bars individually.
Ahmed_Muharram
could you share a screen shot or the file to check
MostafaElashmawy
This can be done using a plugin called Sofistik.
check below link:
https://www.sofistik.de/documentation/2016/en/reinforcement_detailing/cmdref/modify/explode.html
Mostafa Elashmawy
