Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Copying Beam without connection holes
7 REPLIES 7
Message 1 of 8
jrmurdoch
526 Views, 7 Replies
From the picture you will see a beam I copied, how do I reset the beam to remove the holes?
7 REPLIES 7
Message 2 of 8
in reply to: jrmurdoch
Watch this video about still connections
https://youtu.be/5BOwfdWEL80
Message 3 of 8
jrmurdoch
Watched the video, didn't answer how to remove the holes.
Message 4 of 8
YarUnderoaker
Copy one instance. Select holes and delete it. Then do multiple copying.
Message 5 of 8
jrmurdoch
in reply to: YarUnderoaker
How do I select only the holes? I seem to be only able to select the beam.
Message 6 of 8
bin
It’s probably the steel connector there, set the detail level to Fine and tick all the structural connection under VG setting.
Message 7 of 8
You can window select (left to right) the holes and delete them.  Or crossing select (right to left) then use filter to keep the holes and delete them.
Message 8 of 8
 just crate a new beam form structural tab, if that also has holes then edit family.
Forma Design Contest
Technology Administrators
