From the picture you will see a beam I copied, how do I reset the beam to remove the holes?
Copy one instance. Select holes and delete it. Then do multiple copying.
How do I select only the holes? I seem to be only able to select the beam.
It’s probably the steel connector there, set the detail level to Fine and tick all the structural connection under VG setting.
You can window select (left to right) the holes and delete them. Or crossing select (right to left) then use filter to keep the holes and delete them.
just crate a new beam form structural tab, if that also has holes then edit family.
