Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Joist Girder Family
9 REPLIES 9
Message 1 of 10
rsoni
2533 Views, 9 Replies
Joist Girder Family
Anybody have idea where to download JOST GIRDER FAMILY?? OR any tricks to show J.girders in plan/create family????
9 REPLIES 9
Message 2 of 10
in reply to: rsoni
I think there are some in the factory Revit, but look on www.Revitcity.com
they have some.
wrote in message news:5518049@discussion.autodesk.com...
Message 3 of 10
rsoni
in reply to: rsoni
Anybody figured Joist Girders or lintels yet in Revit Strc.?
Message 4 of 10
in reply to: rsoni
i'm not sure if this is what you are looking for.....
If you go to the design bar under basics and click beam in the options bar you'll see usage there you can select if you want a joist, girder etc.....
Message 5 of 10
rsoni
in reply to: rsoni
Revitcity doesn't have anything direct on joist girders.
Hope Autodesk will include Joist Girders/Lintels in next version.
Any one figured out lintels yet?
Message 6 of 10
in reply to: rsoni
I have setup and tested two preliminary JG families. One does not permit
bottom chord extensions, and the other doesn't permit variable seat
extensions. Do to the way I set it up, I have not yet incorporated both
sets of functionality into a single family. It was a bit tricky because
of the equidistant panel spacing array required, and the fact that the
end panel length must accommodate the proper (standard) seat length to
maintain the correct panel point spacing across the entire JG.
For lintels, insert them as you would a beam. I presume you're having
difficulty with them showing correctly in the correct plan. You need to
change the vertical projection to remedy this.
R
Message 7 of 10
Maybe these BIM/Parametric tools available from Canam Buildings will work.
https://www.canam-construction.com/en/engineering-tools/parametric-objects/
Message 8 of 10
Tom_Kunsman
Vulcraft also has a good utility for joist girders and special profile joists http://vulcraft.com/bim-technology/revit
Message 9 of 10
Tom_Kunsman
the canam tools are very old and have not been updated in a long time.
Message 10 of 10
in reply to: Tom_Kunsman
Thanks for the update.  They may serve my purpose as they will only be used for OWSJ creation so that I may coordinate sprinkler piping in joist spaces.
SeaColl
Forma Design Contest
