Hello All. I am trying to copy the wall on the left to a different location. The wall has been edited using ref. plane. When I copy this edited wall to a new location the original wall appears instead of the edited wall. Can anyone help? Thank you.
Solved by ksekhavati. Go to Solution.
Solved by ennujozlagam. Go to Solution.
you need to copy with the reference plane, i think they use the reference plane in cutting geometry or you can add reference plane and use cut geometry to cut the wall. thanks
Thanks for replying. I also have an issue copying steel beams which have been cut in section view between columns using ref. plane from one level to another level. Taking your advice I am unable to see ref. plane on a plan view to be able to copy the beams from one level to another level. I can pick all my steel beams but not the ref. planes which are only visible in section view
Another way is to copy your beam and create a reference plane to cut geometry or make them a group of your beam with reference plane and copy them to the next floor.
