Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
copying an edited element
6 REPLIES 6
ksekhavati
432 Views, 6 Replies
Hello All. I am trying to copy the wall on the left to a different location. The wall has been edited using ref. plane. When I copy this edited wall to a new location the original wall appears instead of the edited wall. Can anyone help? Thank you.Copy Wall.JPG
6 REPLIES 6
ennujozlagam
in reply to: ksekhavati
you need to copy with the reference plane, i think they use the reference plane in cutting geometry or you can add reference plane and use cut geometry to cut the wall. thanks
ksekhavati
Thanks for replying. I also have an issue copying steel beams which have been cut in section view between columns using ref. plane from one level to another level. Taking your advice I am unable to see ref. plane on a plan view to be able to copy the beams from one level to another level. I can pick all my steel beams but not the ref. planes which are only visible in section view
ksekhavati
in reply to: ennujozlagam
ennujozlagam
Another way is to copy your beam and create a reference plane to cut geometry or make them a group of your beam with reference plane and copy them to the next floor.
ksekhavati
Thanks a lot for replying
ksekhavati
Forma Design Contest
