CONICAL ROOF
CONICAL ROOF
CONICAL ROOF
Hi, I am trying to create a 3D steel tank with a conical roof. I have the circular walls created by I can't get the roof to create a cone. Every time I try and apply a slope to it, it slopes the entire roof  from one edge and not the center of it. Thank you. Working in Revit 14 for this project.
dzanta
create the circular walls
start the roof by footprint command
use the pick line method within the contextual draw panel
specify slope within the options toolbar
select the walls...dashed magenta lines will display with slope designation for each curved line
finish the sketch
see image
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
I've done that and all it does is create a round sloped roof. It doesn't create a point in the middle that is higher than the edges
dzanta
verify slope on both curved magenta sketch lines match.
dzanta
if you are viewing your roof in a roof plan, verify your view range has a cut plane that is higher than the roof...
constantin.stroescu
If you want to see the apex of the cone you can use the option : Number of Full Segments from Properties . The Cone will be represented with facets ( aproximating the circle with a Regular Poligon)
a cone with 10x2 = 20 segments
a cone with 20x2 = 40 segments
Constantin Stroescu
