Hello all,
We are trying to convert from precast CAD estimating to Revit. I am creating a schedule of a drawing and need to combine elements with the same length and width in the project. So for example, if I have two 8" walls with the same dimensions we need those to be labeled as a count of 3 instead of itemizing each one separately on the total count schedule.
This is needed due to having 500 pieces on a framing schedule and cutting down on length of report and export time in excel.
Snip is attached of issue.
Thanks!
Solved by ToanDN. Go to Solution.
Sort by those fields and untick Itemize every instance.
Toan Nguyen
Yea I guess that is where I am stuck. I need to itemize all of the elements that have different dim values but group the ones that have the same values. Does revit have this capability?
thanks
Here is a snip to clarify what I mean. For instance in the spandrel section the ones with the same values are grouped together with a count of 4 instead of listing them separately.
Hah! A little slow with revit still. 😂 Yes that worked. I added dim length and width to sort then unchecked itemized. Thank you. Crisis averted.
