Hello all,
We are trying to convert from precast CAD estimating to Revit. I am creating a schedule of a drawing and need to combine elements with the same length and width in the project. So for example, if I have two 8" walls with the same dimensions we need those to be labeled as a count of 3 instead of itemizing each one separately on the total count schedule.
This is needed due to having 500 pieces on a framing schedule and cutting down on length of report and export time in excel.
Snip is attached of issue.
Thanks!
Solved by ToanDN. Go to Solution.
Yea I guess that is where I am stuck. I need to itemize all of the elements that have different dim values but group the ones that have the same values. Does revit have this capability?
thanks
Here is a snip to clarify what I mean. For instance in the spandrel section the ones with the same values are grouped together with a count of 4 instead of listing them separately.
Hah! A little slow with revit still. 😂 Yes that worked. I added dim length and width to sort then unchecked itemized. Thank you. Crisis averted.
