Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Civil 3D pipe network to Revit
3 REPLIES 3
5070 Views, 3 Replies
is it possible to import the pipe networks created in Civil 3D into Revit. I know it is possible to bring in surfaces and road networks but what about the pipe systems.
3 REPLIES 3
kathryn.langan
If the file is exported from an isometric view to a 3D DWG, the geometry should be visible in Revit. They won't be smart objects, but they should display when imported.
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
MikeEvansUK
I'm not sure if the new version is any better at this (judging on Civil3D 2014 probably not).
The best way to get a Civil 3D Pipe network into a Revit model is to use the following workflow.
  • In Civil3d switch to a 3d view and explode twice to get solids and save the file elsewhere.
  • In Revit Structure. Create a new Mass Solid object and import the drawing data and insert to model.
By using this you can cut sections and annotate most of the obejcts however as stated previously the objects will not have any inteligent information.
Whilst were here for surfaces:
  • in civil 3d, explode them to faces, type Region then select all faces.
  • Export regions to drawing or Sat files then import as Mass obect.
Now the surface displays exactly as is was in civil 3d and is sectionable and annotatable.
These are the best workarounds we have until these products play happy together "2015?"
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
michael.warrenNE69V
Export the Civil 3D file to .ifc (Industry Foundation Class) file format and then link into Revit under the IFC tab.
Forma Design Contest
