is it possible to import the pipe networks created in Civil 3D into Revit. I know it is possible to bring in surfaces and road networks but what about the pipe systems.
Solved by MikeEvansUK. Go to Solution.
If the file is exported from an isometric view to a 3D DWG, the geometry should be visible in Revit. They won't be smart objects, but they should display when imported.
I'm not sure if the new version is any better at this (judging on Civil3D 2014 probably not).
The best way to get a Civil 3D Pipe network into a Revit model is to use the following workflow.
By using this you can cut sections and annotate most of the obejcts however as stated previously the objects will not have any inteligent information.
Whilst were here for surfaces:
Now the surface displays exactly as is was in civil 3d and is sectionable and annotatable.
These are the best workarounds we have until these products play happy together "2015?"
Export the Civil 3D file to .ifc (Industry Foundation Class) file format and then link into Revit under the IFC tab.
