Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Automatic Reinforcement from ROBOT results
3 REPLIES 3
karthikb200106
196 Views, 3 Replies
Is there any way to automatically create reinforcement in Revit (For walls, beams etc.,) by using the results from ROBOT SA software?
It is also if any one has an idea about how to create automatic reinforcement using dynamo!. Found some packages in online but can't download those in my dynamo.
Thank you.
3 REPLIES 3
There were once addins called Revit Extensions and some software houses (Naviate & CADS RC3D) have adopted them and offer them as Revit Addin Tools.
CADS Rebar Extensions for Autodesk® Revit® - 2023 | Revit | Autodesk App Store
In these there used to be a minimum reinforcement Tab whereby As req. values could be imported from Robot to get a semi-automated layout/output but not sure if this is still an option?
Alternatively would be to use the automation processes in Robot using the Analysis Results and then transfer the Rebar from Robot into Revit using the Integration Tool between Revit & Robot.
Jay Colcombe
Autodesk Certified Instructor
Apart from extensions.
While integrating the robot to revit the reinforcement is not transferring.
This indicates it is not longer possible
Is it possible to export provided reinforcement calculated in Robot Structural Analysis 2023 and lat...
Jay Colcombe
Forma Design Contest
Technology Administrators
