Is there any way to automatically create reinforcement in Revit (For walls, beams etc.,) by using the results from ROBOT SA software?
It is also if any one has an idea about how to create automatic reinforcement using dynamo!. Found some packages in online but can't download those in my dynamo.
Thank you.
Solved by jay_colcombe. Go to Solution.
There were once addins called Revit Extensions and some software houses (Naviate & CADS RC3D) have adopted them and offer them as Revit Addin Tools.
CADS Rebar Extensions for Autodesk® Revit® - 2023 | Revit | Autodesk App Store
In these there used to be a minimum reinforcement Tab whereby As req. values could be imported from Robot to get a semi-automated layout/output but not sure if this is still an option?
Alternatively would be to use the automation processes in Robot using the Analysis Results and then transfer the Rebar from Robot into Revit using the Integration Tool between Revit & Robot.
This indicates it is not longer possible
