'Enable analytical model ' toggle is missing for structural elements
alifmuhammed459
alifmuhammed459
I am fairly new to Revit and i am facing an issue where i can't create the  analytical model for my RCC model. I created a physical model using  the structural template and when i go to analytical view, it's empty. I tracked down the problem to the analytical model not being enabled, but i can't find the toggle to turn it on. I have all the analytical parameters turned on in the visibility graphics setting.
One more thing, I am using a student license (i have seen the same issue with my friends too).
I have attached screenshots and the sample file. Thanks in advance and sorry for my bad English.
Ahmed_M_Heteba
if you are using Revit 2023 this is the new method check the link
https://knowledge.autodesk.com/support/revit/getting-started/caas/CloudHelp/cloudhelp/2023/ENU/Revit...
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
alifmuhammed459
Thank you for replying, but your suggestion doesn't seem to work.
I still can't enable the analytical model from the properties tab. Structural settings doesn't have an analytical tab for me to enable auto-detect either.
I can add analytical member from the analyse tab manually, but that's not practical for a large project. Is there a global setting for this that I am unaware of?, or is this a bug?
I have attached screenshots of the mentioned widows and a sample file.
Ahmed_M_Heteba
there is no longer analytical enable in proprieties, you have to use dynamo to generate it
check video https://youtu.be/4ClsmT-EMzY
guillecayon
Hey, did you find a solution for this?
I have the same problem through all my revit programs and can't find a solution.
ehaque7MCD89
Community Visitor
Community Visitor
just use template "Structural Analysis-Default.rte" problem will solve
