Adding a thickened slab edge to a sloped slab
soriale
soriale
I have tried to use a model-in-place to add thickened slab edge to a sloped floor, and it didn't follow the slope.
And then I tried flattening the floor and adding the slab edge and adjusting the floor elevations again, but it also didn't work. I can't get it to follow the floor slope.
jay_colcombe
Please try one of the following methods.  (The first 2 relate to actual placement which is more difficult with slopes)
Method 1
If you are using the slope arrow to slope your slab, you can flatten the slab, add the edges, and then re-slope it. The edges will follow the slope.
Method 2
If you are using the Slab Shape editing tools or you do not want to flatten the slab, you can draw a model line along the sloped slab edge. You can then select this line when placing the slab edge, rather than the slab itself.
Method 3
Model In-Place Sweep and create the Sweep manually and ensure you fill in the missing slope element (you could use the existing Slab Edge as a guide then delete after)
Jay Colcombe
Autodesk Certified Instructor
handjonathan
Hi @soriale
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Jason.P
like option 1 or 2. I will have to try this on my next project
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
Adjust Vertical Profile Offset.
