Hi, I would like to give my concrete beams an additional annotation of TOC, I have created an additional annotation that I have to manually switch each beam to. I do not want the same additional annotation on my steel beams. Is there a way to make the default annotation for CONCRETE beams different from that of steel beams? When I go to Loaded Tags and Symbols, there is no Category for beams, only Beam Systems and Framing. At this moment my beams fall under the Structural Framing Tags (and is I change the tag for the framing, all of my truss tags change as well).
Thank you
