Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Automate different annotations for beams of different compositions
1 REPLY 1
jessvdm2024
109 Views, 1 Reply
Hi, I would like to give my concrete beams an additional annotation of TOC, I have created an additional annotation that I have to manually switch each beam to. I do not want the same additional annotation on my steel beams. Is there a way to make the default annotation for CONCRETE beams different from that of steel beams? When I go to Loaded Tags and Symbols, there is no Category for beams, only Beam Systems and Framing. At this moment my beams fall under the Structural Framing Tags (and is I change the tag for the framing, all of my truss tags change as well).
Thank you
1 REPLY 1
Tom_Kunsman
in reply to: jessvdm2024
I think the only way to automate this would be thru Dynamo
Forma Design Contest
Technology Administrators
