Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Assembly Level
7 REPLIES 7
Message 1 of 8
GatisM
1871 Views, 7 Replies
Assembly Level
Hello everyone,
I have roof truss modeled with Structual Framing and Structural Connection elements, from wich I created Assembly element. In properties for Structural Framing and Structural Connection elements assigned Roof Level. For Assebly I can't assign anything (right?). Exporting to ifc , ifc viewer are automatically assigning for all elemnts 1st Level. is it possible assign level for assembly, and export with right Building Storey?
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
L.Maas
in reply to: GatisM
Try this:
-Create a (instance) project parameter IfcSpatialContainer and assign it to assemblies
-In your assembly fill in the appropriate level. Make sure the level exists (check spelling and case)
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
GatisM
in reply to: L.Maas
Very big thank you!
Message 4 of 8
waly36ARJ
in reply to: L.Maas
How did you create this level please I have the same problem
Message 5 of 8
kaspars
in reply to: waly36ARJ
Create Shared Paremeter named IfcSpatialContainer as Text parameter assign property to necessary categories (assmblies in you case), and than select element and in property palette in newly created parameter IfcSpatialContainer type in choosen level name.
If don't no how to create shared parameters etc., search in forum or other channels there ar lot of information.
Message 6 of 8
waly36ARJ
in reply to: GatisM
Thank you will try this one
Message 7 of 8
waly36ARJ
in reply to: GatisM
it did not work for me I just want to see the project level in the elevation assembly view .
Message 8 of 8
GatisM
By default Assemblies has no ifc parameter assigned to level and in ifc viever no such parameter to read, just add additional parameter as i wrote before.
see picture attached
Forma Design Contest
