The 120V receptacle will not connect to the 120/208V panel.
MasterSpark517
Message 1 of 15
MasterSpark517
How do I get a 120/208V 3PH/4W panel to allow 120V receptacles to connect? I have added the 120/208V 3PH/4W Wye Distribution System in the MEP Settings and set the L-G Voltage to 120. The families  are provided and a screen shot of electrical settings with the error also provided.
Replies (14)
Message 2 of 15
ricaun
I tested and works fine on the Imperial System Revit Template on Revit 2021.
Check if your Panel has the right Distribution. (Probably is empty)
And check your Electrical Setting Voltage Minimal and Maximum
I hope this helps.
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 3 of 15
robert.klempau
Hello @MasterSpark517,
Please check if the Type parameter 'BI_Voltage' has the correct value.
Check also the Voltage Definition.
set the Minimum and Maximum values right.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 4 of 15
MasterSpark517
It was an altered panel. I found one that worked and it connected.
Message 5 of 15
MasterSpark517
I noticed you have the minimum and maximum +- 10V. Should I use a 10V separation?
Message 6 of 15
MasterSpark517
I'm still having this problem.
"Cannot assign or add UPS-1-C-4 to Circuit. The Voltage () for the Circuit is out of range for the Line to Ground Voltage for UPS-1-C-4 (The Line to Ground Voltage is specified in the assigned Distribution System)."
Message 7 of 15
ricaun
You need to select your Panel and choose a valid Distribution System.
If this is empty your circuit is not able to connect to the panel.
Message 8 of 15
MasterSpark517
That's just it; it's not empty.
Message 9 of 15
ricaun
Send images, gonna be easy to find the problem.
  • What Voltage is your circuit?
  • What Distribution System are you using on the Panel?
  • What are your minimum and maximum voltage on the Voltage Definitions?
Message 10 of 15
MasterSpark517
As did I and it does work. This means there's a glitch in my project file that's preventing the two to connect.
I have the Distribution system correct.
Message 11 of 15
MasterSpark517
This is not the case.
Message 12 of 15
ricaun
If you could share your project file should be easier to find where is the problem.
Delete everything, just this panel, and the circuits on the project file.
See yaa!
Message 13 of 15
fabiosato
To connect a load to this panel, it must be a single phase load 120V.
Fábio Sato
Message 14 of 15
MasterSpark517
I realize that. Since this posting, I've discovered there were too many circuits and too many panels with the same name; they were in different design phases. I ended up deleting several abandoned items and the connecting to panels began to work.
Thanks for you help.
Message 15 of 15
MasterSpark517
