MEP Fabrication Ductwork <Beyond> Line Style has no effect
CVDemick
CVDemick
I have a Revit Model where there is MEP Fabrication ductwork being used. In my view I am trying to get the ductwork that is under the floor to show up as a dashed line. I have set my view range so that the ductwork that is under the slab is within the range between the Bottom and View Depth parameters and I have ensured that the <Beyond> line style is set to display a Grey Dashed Line.
The <Beyond> Line Style doesn't appear to have any effect on the ductwork but it does change all he RFA's I have attached to the system. The other items I have checked so far are:
  • Verified that there are no categories overridden in the VG settings.
  • Verified there are no Filters overriding the MEP Fabrication Ductwork line styles.
  • Verified that the Hidden Line Style is set for the view
  • Verified that the Floor in the Linked Architectural Model is visible.
  • Verified the discipline for the view is set to Mechanical instead of Coordination.
Has anyone else run across this or have a solution/work around that is not utilizing (2) Views stacked on top of each other? (see this post for similar issues https://forums.autodesk.com/t5/revit-mep-forum/ductwork-under-a-slab/m-p/4777689#M21931)
robert.klempau
Hello @CVDemick,
I also tested it myself and I have your findings as well,
That is why I forwarded this question to Autodesk support.
through my support channel. Hopefully, they have an answer.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
