routing preference problem
mtanyer
mtanyer
Dear all,
I am trying to convert the "tee" to a "cross" by clicking the + sign.
I think the cross family is defined in the routing preferences.
However, the system gives me the following error message:
"The converted fitting was not defined in the routing preference. Please assign one on the connected curve types."
What could be the reason for this?
Thank you
ReActionCAD
That is the answer. Do you know how to check the routing preferences and assign the cross?
I checked your model and everything looks good and the conversion from "tee" to "cross" works.
pkomatlapalli
Hi @mtanyer ,
Can you please confirm whether ReActionCAD   response addresses your issue. If yes, please consider marking it as the "Accepted solution" button. Doing so helps other community members quickly identify the most relevant answer and serves as a useful reference for users facing similar issues.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Pavan Kumar
