I have this drain that goes underground, and I want to create punchouts for pipe to go through. I create a void extrusion on the right side of the drain and it cut just fine turned on Cut Geometry in the properties tab. But when I created another void extrusion on the left side it doesn't cut and I turned on Cut Geometry. I also don't want to use the cut command because I want to be able to turn the cuts on and off when I import it into my project
