Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Model into model
2 REPLIES 2
jtgel
124 Views, 2 Replies
Model into model
I have an Architectural model that I am linking into the HVAC so I can do the HVAC. We are also expecting a PLBG model seperately. Is there a way to link the PLBG model into the HVAC & explode it so we can work on it similar to Autocad. I know that if worse comes to worse I can have (2) seperate models & then link the plumbing into the HVAC & keep overwriting it but I would prefer to work in one model if possible.
2 REPLIES 2
iainsavage
in reply to: jtgel
Link in the plumbing model.
Select the link and Bind it.
It will come in as a group.
Select the group and ungroup it.
You may however find that some connections will disconnect when you ungroup, similar to this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Elements-needs-to-...
jtgel
in reply to: jtgel
TY
Forma Design Contest
Technology Administrators
