I have an Architectural model that I am linking into the HVAC so I can do the HVAC. We are also expecting a PLBG model seperately. Is there a way to link the PLBG model into the HVAC & explode it so we can work on it similar to Autocad. I know that if worse comes to worse I can have (2) seperate models & then link the plumbing into the HVAC & keep overwriting it but I would prefer to work in one model if possible.
Solved by iainsavage. Go to Solution.
Link in the plumbing model.
Select the link and Bind it.
It will come in as a group.
Select the group and ungroup it.
You may however find that some connections will disconnect when you ungroup, similar to this:
