Disable Printer
Disable Printer
zbischof
Disable Printer
zbischof
Is there a way to disable printers in Revit or force it to default to PDF first. I cant tell you how many times I've printed a set of E1's by accident.
hmunsell
Revit should use what ever printer is set as default on your PC.
  • Got to Printers & Scanners on your PC
  • Select the printer you want to use
    • Pick the Manage button
    • Pick the Set as Default
Howard Munsell
You can set windows default printer to a PDF printer but it affects all other programs, not just Revit.  You can use export to PDF instead of print in Revit so it always PDF.
HVAC-Novice
Use export function to create PDF.
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
zbischof
Thank You!
