Is there a way to disable printers in Revit or force it to default to PDF first. I cant tell you how many times I've printed a set of E1's by accident.
Solved by hmunsell. Go to Solution.
Revit should use what ever printer is set as default on your PC.
Howard Munsell
You can set windows default printer to a PDF printer but it affects all other programs, not just Revit. You can use export to PDF instead of print in Revit so it always PDF.
