Revit MEP Forum
Disable Printer
4 REPLIES 4
zbischof
213 Views, 4 Replies
Disable Printer
Is there a way to disable printers in Revit or force it to default to PDF first. I cant tell you how many times I've printed a set of E1's by accident.
4 REPLIES 4
hmunsell
in reply to: zbischof
Revit should use what ever printer is set as default on your PC.
  • Got to Printers & Scanners on your PC
  • Select the printer you want to use
    • Pick the Manage button
    • Pick the Set as Default
Howard Munsell
You can set windows default printer to a PDF printer but it affects all other programs, not just Revit.  You can use export to PDF instead of print in Revit so it always PDF.
HVAC-Novice
Use export function to create PDF.
Revit version: R2024.2.1
zbischof
Thank You!
Forma Design Contest
Technology Administrators
