I have linked and imported a dwg file into my Revit MEP 2014 dwg. It is not showing up. I have checked my visibility graphics and my view range. I'm not sure what else I need to look at.
Solved by minusculelighting. Go to Solution.
One more tip, after trying most of the other ideas I found that when linking CAD into a view, as opposed to the model, it would not work if I was working on a sheet in an active view. I had to open the view properly and link the CAD there.
Thank you- this worked.
Now, will Autodesk (a) fix this terrible bug, (b) gaslight us into thinking that there's some very sophisticated reasons why it works this way, or (c) completely ignore it and let this thread run for another decade without comment?
Sorry, nothing for Autodesk to do here. The feature works when it is used correctly.
I have the same problem. I see CAD file in 3D, I moved it up and I don't see it in 2d view. I inserted in 2D view with error "none of the elements ... bla bla" .So I need to dig...
Hey guys, Import your linked CAD into a drafting view first. And then copy it over to the view you need it in.
@User_2011 wrote:I have the same problem. I see CAD file in 3D, I moved it up and I don't see it in 2d view. I inserted in 2D view with error "none of the elements ... bla bla" .So I need to dig...
i'm having the same issue. I inserted a cad file, in my plan view, and it worked as it should. I inserted a second cad file (actually was a copy and edit of the first cad file - so both cad files are very similar). And 2nd file does not show up in the plan view. I can't figure out why i can't see the second file except in 3-d view, even repathing the first file to my second file, the second file still wont show up where the first did!. I've checked worksets, they are both at the same "level". I've checked visibility. I removed the file and tried to insert again. . i removed all view cubes, I'm at a loss. please share if you've been able to solve your issue. (if you can remember)
I created a generic model (model in place) and added a model line to it just to show me where it was at. Closed the generic model. Then I copied the DWG import into the generic model and deleted the original import. This worked for me. Hope it works for you.
Another possible cause is that the CAD link is in Background, so bits of it are hidden under the model. To solve this select the portion of the CAD link that you can see and go to Properties, Other, Draw Layer, and change to Foreground.
CAN YOU PLEASE EXPLAIN THIS ISSUE IN MORE DETAIL I DO NOT UNDERSTAND WHAT IS THIS. BUT I AM FACING THE SAME PROBLEM.
MY MAN I ABSOLUTELY LOVE YOU THANKS THIS WORKED AFTER 2 DAYS OF PAIN TO IMPORT MY CADS
Also, it is essential to start with a floor plan and not on a sheet.
I hope that helps
Previously when I tried importing it got imported pretty well now I just can't find my cad file even after importing several times.
If you can't see something it doesn't mean that its not there and re-importing several times will just create multiple instances.
Instead of importing multiple times, solve the visibility issue.
Are you able to upload your model?
Best to check in a 3D view.
DWG files with high values in elevation may be hard to find.
Fábio Sato
