Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
IF/THEN Formula and "Yes/No" Parameter
57 REPLIES 57
Message 1 of 58
clippincott-CL
279962 Views, 57 Replies
I have created two "Yes/No" parameters in a family and associated each of them with the visibility of a different symbol in the family. If one of these parameters is set to "Yes", I want the other set to automatically be set to "No", and vice/versa.
I was trying to achieve this by making a formula that basically says, IF X=Yes THEN Y=No but I don't know how to reference the values of "Yes" or "No" in my formula, Revit tells me that "Yes" and "No" are not valid family parameters. I also tried "True" and "False" but got the same result.
Any ideas as to how I can do this? Any suggestions will be appreciated.
57 REPLIES 57
Message 21 of 58
L.Maas
Few issues:
-If you make a communication device schedule, your nested families should also belong to that category to be able to show up in the schedule (now it is generic)
-You have to make the nested families Shared to be able to schedule them.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 22 of 58
in reply to: L.Maas
@EnlInt wrote:
Few issues:
Thank you, Enlint.
That all makes sense. Everything works perfect now. Thanks, again. Kudos to you.
Message 23 of 58
GTisRuleX
in reply to: Martin__Schmid
I've been trying to figure out how to do this for a few years now.  FINALLY stumbled across this post on a google search!
THANK YOU!
Message 24 of 58
in reply to: clippincott-CL
Adding this because nobody else had it...
I have made dummy "Yes" and "No" parameter with the checkmark on/off respectively. Then if I have a family that has multiple options I can create an IF equation that allows me to refer back to "Yes" or "No".
Ex: if(Window Option < 1, No, if(Window Option > 3, No, Yes))
In the above equation I wanted one element to be visible for options 1-3 only. It could also be written on the long way with:
if(Window Option = 1, Yes, if(Window Option = 2, Yes, if(Window Option = 3Yes, No)))
Message 25 of 58
Here we go .
1. When you need to check one of two parameter
2. When you have more than two parameters. Where "Visibility of ABC" is a integer data type..
TIP 1: Use "_" instead of "-" in a parameter name
TIP 2:  https://www.revitforum.org/tutorials-tips-tricks/1046-revit-formulas-everyday-usage.html
"Revit Lies in the tension between what we want to do and what can be done!"
Message 26 of 58
joekozelka
That worked
Thanks!
Joe
Message 27 of 58
Hi, I have a question relating to this topic but can't figure out the solution.
I have three YES/NO parameters A, B, and C. Parameter A is only visibly when a certain condition is met and is working as intended. Parameter B is a simple tick box (YES/NO instance parameter).
What I want to achieve is the following: If  A=YES, then  C=NO. If  A=NO, then  C=NOT(B). I cant't manage to pour this functionality into a formula for parameter C. Anybody any idea's?
Message 28 of 58
in reply to: luis_brionesalonso
Right now I assume you have certain conditions that control "A" being checked on unchecked.
Use the following equation:
C =IF(A, not(A), not(B))
If the conditions for A are met, then use the opposite of A. If not, then use the opposite of B.
Message 29 of 58
if(not(A), A, not(B))
Message 30 of 58
luis_brionesalonso
in reply to: ToanDN
Works like a charm, thank you.
Message 31 of 58
in reply to: Alfredo_Medina
It's really working. Thanks for sharing this.
Message 32 of 58
hope some one can help me with this problem i have with a formula.
i have a pipe accessory with 2 flange you can turn on and off with the YES/NO parameter.
this is the formula i got written now: if(Flens lengte = 55 + Flens_1 = , 55 mm, if(Flens lengte = 52 + Flens_1 , 52 mm, 1 mm))
but i cant figure out how to write the YES/NO Flens_1 value.
hope i made it a bit clear
Message 33 of 58
Are you able to accept the formulas as they are now? I would assume you cannot. It looks like you have an extra "=" sign. Additionally, you should not be able to add 55mm+Flens_1 because they do not have the same units (Flens_1 is just a yes/no parameter). I am not sure what you are trying to accomplish when you add Flens_1 in that formula.
Message 34 of 58
well my idea behind this formula is that it has to look at 2 if statements, because i got 2 diffrent lenght type's of flange.
i want the formula to first look at the size of the flange if its 55mm if that's true it has to look at the yes/no parameter and if thats also true the lengt will be 55 mm. if one of those are false then the formula has to look further again at the size of the flange if its 52mm and at the yes/no parameter the size of the flange will go to 52mm, if both formula's are false the size of the flange has to become 1mm. but the problem i have is, i dont know how to write the yes/no parameter properly in this formula.
i hope i made it a bit clearer, the is one of my first times im working with these kind of formula writing.
Message 35 of 58
Thanks!!
I stay in 2019 and your reply help me 😄
Message 36 of 58
"Yes", "true","false" or "no" are not constants in Revit.
However, you can get boolean value by typing an expression! E.g. 0=0 returns True, 0=1 returns False.
For shure, theese expressions can be used in formulas.
Bonus: there's also a fun trick with repeating condition expression three times.
Formula =if(a>1, a>1, a>1) returns True when exression is true, and False when not.
UPD: of course, in last case  =a>1   is just enough.
Message 37 of 58
I have a similar issue. I have a lighting track family and need one head type not to exist if the track is shorter than 6'-0". If the track is 6-10' there should be x1 head shown, after that the math works out fine for the family. I tried adding an IF parameter but it tells me I have invalid value or inconsistent units, or my family breaks.
Message 38 of 58
Thank you for this, Alfredo. Using your example, is there a way to limit the range of acceptable integers to 1-4?
Message 39 of 58
please find the below revit file in the attachment, go to family parameter and go down to others there u can find the yes/no with if formula
Message 40 of 58
Revit cannot recognized "True" "False" in formula but you can use a false statement and true statement.
For example, in your case. Lets say "V1" and "V2" as the two visibility parameters you want to control.
I will write formula for "V2" as follow,
"V2" = if(V1, 1>2, 1<2)
I use 1>2 as false statement and 1<2 as true statement, you can also use other type of statement. so this formula means "if V1 is true, V2 is false(1>2) otherwise V2 is true(1<2)". And you can control "V1" as instant parameter or formula, as long as "V1" is on "V2" will off.
I hope this will helpful for your case Cheers!
