Solved by ToanDN. Go to Solution.
Solved by fabiosato. Go to Solution.
Solved by Martin__Schmid. Go to Solution.
Few issues:
-If you make a communication device schedule, your nested families should also belong to that category to be able to show up in the schedule (now it is generic)
-You have to make the nested families Shared to be able to schedule them.
Louis
Please mention Revit version, especially when uploading Revit files.
@EnlInt wrote:Few issues:
Thank you, Enlint.
That all makes sense. Everything works perfect now. Thanks, again. Kudos to you.
I've been trying to figure out how to do this for a few years now. FINALLY stumbled across this post on a google search!
THANK YOU!
Adding this because nobody else had it...
I have made dummy "Yes" and "No" parameter with the checkmark on/off respectively. Then if I have a family that has multiple options I can create an IF equation that allows me to refer back to "Yes" or "No".
Ex: if(Window Option < 1, No, if(Window Option > 3, No, Yes))
In the above equation I wanted one element to be visible for options 1-3 only. It could also be written on the long way with:
if(Window Option = 1, Yes, if(Window Option = 2, Yes, if(Window Option = 3, Yes, No)))
Here we go .
1. When you need to check one of two parameter
2. When you have more than two parameters. Where "Visibility of ABC" is a integer data type..
TIP 1: Use "_" instead of "-" in a parameter name
TIP 2: https://www.revitforum.org/tutorials-tips-tricks/1046-revit-formulas-everyday-usage.html
Hi, I have a question relating to this topic but can't figure out the solution.
I have three YES/NO parameters A, B, and C. Parameter A is only visibly when a certain condition is met and is working as intended. Parameter B is a simple tick box (YES/NO instance parameter).
What I want to achieve is the following: If A=YES, then C=NO. If A=NO, then C=NOT(B). I cant't manage to pour this functionality into a formula for parameter C. Anybody any idea's?
Right now I assume you have certain conditions that control "A" being checked on unchecked.
Use the following equation:
C =IF(A, not(A), not(B))
If the conditions for A are met, then use the opposite of A. If not, then use the opposite of B.
if(not(A), A, not(B))
hope some one can help me with this problem i have with a formula.
i have a pipe accessory with 2 flange you can turn on and off with the YES/NO parameter.
this is the formula i got written now: if(Flens lengte = 55 + Flens_1 = , 55 mm, if(Flens lengte = 52 + Flens_1 , 52 mm, 1 mm))
but i cant figure out how to write the YES/NO Flens_1 value.
hope i made it a bit clear
Are you able to accept the formulas as they are now? I would assume you cannot. It looks like you have an extra "=" sign. Additionally, you should not be able to add 55mm+Flens_1 because they do not have the same units (Flens_1 is just a yes/no parameter). I am not sure what you are trying to accomplish when you add Flens_1 in that formula.
well my idea behind this formula is that it has to look at 2 if statements, because i got 2 diffrent lenght type's of flange.
i want the formula to first look at the size of the flange if its 55mm if that's true it has to look at the yes/no parameter and if thats also true the lengt will be 55 mm. if one of those are false then the formula has to look further again at the size of the flange if its 52mm and at the yes/no parameter the size of the flange will go to 52mm, if both formula's are false the size of the flange has to become 1mm. but the problem i have is, i dont know how to write the yes/no parameter properly in this formula.
i hope i made it a bit clearer, the is one of my first times im working with these kind of formula writing.
"Yes", "true","false" or "no" are not constants in Revit.
However, you can get boolean value by typing an expression! E.g. 0=0 returns True, 0=1 returns False.
For shure, theese expressions can be used in formulas.
Bonus: there's also a fun trick with repeating condition expression three times.
Formula =if(a>1, a>1, a>1) returns True when exression is true, and False when not.
UPD: of course, in last case =a>1 is just enough.
I have a similar issue. I have a lighting track family and need one head type not to exist if the track is shorter than 6'-0". If the track is 6-10' there should be x1 head shown, after that the math works out fine for the family. I tried adding an IF parameter but it tells me I have invalid value or inconsistent units, or my family breaks.
Thank you for this, Alfredo. Using your example, is there a way to limit the range of acceptable integers to 1-4?
please find the below revit file in the attachment, go to family parameter and go down to others there u can find the yes/no with if formula
Revit cannot recognized "True" "False" in formula but you can use a false statement and true statement.
For example, in your case. Lets say "V1" and "V2" as the two visibility parameters you want to control.
I will write formula for "V2" as follow,
"V2" = if(V1, 1>2, 1<2)
I use 1>2 as false statement and 1<2 as true statement, you can also use other type of statement. so this formula means "if V1 is true, V2 is false(1>2) otherwise V2 is true(1<2)". And you can control "V1" as instant parameter or formula, as long as "V1" is on "V2" will off.
I hope this will helpful for your case Cheers!
