Add Save As to quick access toolbar?
pteague
Message 1 of 9
pteague
Just wanted to double check that it is still not possible to add "Save As" to the quick access toolbar.  Is that correct?
Replies (8)
Message 2 of 9
RobDraw
If you have to ask, it doesn't sound promising. I'd check to see if it's available but I don't have the latest version. Do you?
Rob
Message 3 of 9
pteague
I have 2020, 2021, & 2022.
Message 4 of 9
RobDraw
Have you checked?
Rob
Message 5 of 9
pteague
I don't even know where one would check.  That's why I'm asking.  You can right-click most other buttons to add to the toolbar, but there's not even a place to right-click the save-as button.
Message 6 of 9
iainsavage
How often do you need to save a file as another file to justify having it on your QAT?
That's probably why its not available.
On my QAT I have things like split, trim, extend etc - for save as I would just go to file>save as rather than cluttering up the QAT.
I know this doesn't actually answer your question but maybe will be of some assistance.
Message 7 of 9
You could add a keyboard shortcut for Save As.
Message 8 of 9
pbarreraLHDRC
Observer
Observer
If this the workaround people are using? Coming over from AutoCAD and using the Save-As to make version changes at Benchmark model changes, I'm miffed that I can't figure out how to add it to the QAT like I did in AutoCAD
Message 9 of 9
HVAC-Novice
There is no saving to an older version in Revit. That removes most of the need for the "save as".
https://revitlink.blogspot.com/2017/05/why-is-revit-not-backwards-compatible.html
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
