We want to use package with manufactorer-made families in our standard revit project.
When loading a manufactorer-family into our project the error occurs.
It seems that the same shared parameter indentifier is used for two different parameters.
How can we use the manufactorer-families (approx 300) in our standard project?
Louis
Please mention Revit version, especially when uploading Revit files.
Since the manufactorer standard contains over 300 families and is updated yearly, our solution is most likely that we change the parameter in our template project (hopefully less families)
You cannot force the GUID change. You would have to introduce a parameter with a different GUID number and update the families manually or using dynamo.
You can use an app, unfortunately the ones are paid ones.
Fábio Sato
