Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Family don't calculates airflows.
2 REPLIES 2
365 Views, 2 Replies
Hi.
I try to create family of AHU. I created very easy example, because I wanted to check how is it works. There are 4 connectors.
- air from room
- supply air to room
- fresh air
- exhaust air
I connected air from room with exhaust air diffusers, and supply air wit supply air diffusers. They have set som airflows. I would like to, connector of fresh air took the value of supply air etc. What i done wrong, why is not working?
Thank you for replies.
I attach data.
2 REPLIES 2
dbutts7
Here's a link to a post I wrote about air flow settings in Revit...it's based on 2013 but the theory is the same - let me know if it helps explain how this works -
http://mep-cad.blogspot.com/2013/01/getting-in-flow-with-revit-hvac.html
thanks - David B.
David A. Butts
Engineering Technology Manager - Gannett Fleming
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
The MEP BIM/CAD Engineer Blog
dbutts7
in reply to: dbutts7
For connecting air flow values from one connector to another, you can accomplish this by adding a parameter that is defined as a formula for the other airflow value. The rules are important to follow:
- the values must be the same format - in other words, this works best when both parameters use the default Air Flow units - you don't want to combine common text with a duct specific Air flow parameter
- the values must be defined in the same family, to "inherit" the same values. Don't try to do this as a project parameters, it needs to be specific to the part
- Make the airflow value instance based, so you can make adjustments based on the exact airflow at the unit, rather than by the type.
hope this helps - thanks - David B.
David A. Butts
Forma Design Contest
Technology Administrators
