Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
fabrication pipe routing preferences
1 REPLY 1
shawnchambers
276 Views, 1 Reply
I know I've seen this setting before (I think)...  How do I configure the multipoint routing preferences for Fabrication Pipe?  (Not the auto-fill exclusions)
Example -
If I have a 2" pipe at 10'-0" and I use multipoint routing to tap off a 1" pipe and run at 8'-0", Revit will run the pipe straight down to 8'-0" and then place a 90 to run horizontal.
But if I tap off that same 10'-0" and try to run at 9'-6", Revit will tap off at 45 degrees and then place a 45 to run horizontal.
I know why it's doing this... but I'd like to dial back how far the run is before it auto changes from 90 to 45.
1 REPLY 1
MOatman
in reply to: shawnchambers
I don't think it is possible to modify or control the routing preferences on fabrication parts at this time.
Forma Design Contest
Technology Administrators
