I know I've seen this setting before (I think)... How do I configure the multipoint routing preferences for Fabrication Pipe? (Not the auto-fill exclusions)
Example -
If I have a 2" pipe at 10'-0" and I use multipoint routing to tap off a 1" pipe and run at 8'-0", Revit will run the pipe straight down to 8'-0" and then place a 90 to run horizontal.
But if I tap off that same 10'-0" and try to run at 9'-6", Revit will tap off at 45 degrees and then place a 45 to run horizontal.
I know why it's doing this... but I'd like to dial back how far the run is before it auto changes from 90 to 45.
