Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
deleting elements
5 REPLIES 5
Jacob.Riley
292 Views, 5 Replies
deleting elements
I am trying to delete an element in a model and it is stating that it was deleted in the central model and i am the only on working on model. Can anyone tell me what is going on here or help out.
5 REPLIES 5
RobDraw
in reply to: Jacob.Riley
Synch (make sure to relinquish everything, close, and reopen to see if that solves it for you.
Rob
Jacob.Riley
in reply to: RobDraw
I did that before posting and did not do anything for me still giving me same issue. Its on the cloud so also published latest and that did nothing also.
RobDraw
You are opening from the cloud, correct?
How about downloading it from the cloud and then opening it detached from central, save, test, delete model from cloud, and then collaborate in the cloud again?
Rob
Jacob.Riley
Thats what my options are going to be tomorrow. Was trying to find solution that didnt require this if at all possible.
RobDraw
You can also try deleting your local file. It's file path is something like:
C:\Users\[Your User Name Here]\AppData\Local\Autodesk\Revit\Autodesk Revit [20XX]\CollaborationCache
The file name will not indicate the project. Feel free to empty this folder.
Rob
Forma Design Contest
Technology Administrators
