Hello, i'm doing some test for energy analisys, but the temperatures from the weather station near the test project location aren't right (weather station 936763) i know it beacuse i live where the station is. is there a way to uplodad corrected data to the autodesk server? I tried to manually update the weather tab, but the energy anlisys doesnt run with that option. Any other ideas?
Hi, we're sorry to hear that you're encountering an issue. In order to help you resolve this, could you please let us know what is the site/location that you are checking, so that we can check the data?
Also, which of the following processes are you using the weather data for?
(a) standard heating/cooling loads calculations
(b) more recently added systems analysis (annual sim or system sizing)
(c) Insight energy optimization on the cloud
We need to establish the form of the analysis and the location in order to access the right data, and help you in the right way. Thanks!
Note that the standard heating & cooling loads calculations do not use the OneBuilding data, but a slightly older set.
In addition, there are (currently) two ways of carrying out the sizing operations:
(a) long-established heating & cooling loads which uses slightly older data – I think this is what you’re using now.
(b) newer systems analysis sizing process (https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...) which should use the OneBuilding data.
We are looking to consolidate this to a single process which will use just the .epw data, but there are these different options at the moment.
Could you see if you experience the same issue if you try the sizing with the newer process? This will ultimately replace the older calculation because it uses the .epw data and EnergyPlus as the engine.
