I am trying to delete an element in a model and it is stating that it was deleted in the central model and i am the only on working on model. Can anyone tell me what is going on here or help out.
Synch (make sure to relinquish everything, close, and reopen to see if that solves it for you.
I did that before posting and did not do anything for me still giving me same issue. Its on the cloud so also published latest and that did nothing also.
You are opening from the cloud, correct?
How about downloading it from the cloud and then opening it detached from central, save, test, delete model from cloud, and then collaborate in the cloud again?
Thats what my options are going to be tomorrow. Was trying to find solution that didnt require this if at all possible.
You can also try deleting your local file. It's file path is something like:
C:\Users\[Your User Name Here]\AppData\Local\Autodesk\Revit\Autodesk Revit [20XX]\CollaborationCache
The file name will not indicate the project. Feel free to empty this folder.
