Revit MEP Forum
can't see equipment in Callout
7 REPLIES 7
Message 1 of 8
mehrdadjavaherihotmail_com
346 Views, 7 Replies
As you can see in the pictures the equipment (pumps) not show in callout
plan view and callout have same view template
Callout ViewCallout ViewPlan viewPlan view
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
You'll need to upload the model please, or if that is not possible then screenshot the view settings, view template settings, view ranges etc and attach those please.
Message 3 of 8
Scale can affect what shows up on callouts.  What scale is the callout at?
Message 4 of 8
Create the callout as a floor plan view, not a detail view.
Message 5 of 8
RobDraw
in reply to: sragan
That's new to me. How is that done?
Rob
Message 6 of 8
It looks like you may have different view ranges. If they are the same, the view template may not be set to control everything.
Rob
Message 7 of 8
Thanks all for your replies. I found the solution. In visibility setting(VG), imported categories, imports in families was off.
Message 8 of 8
And THAT wasn't being controlled by the view template? Really?
Rob
Forma Design Contest
Technology Administrators
