As you can see in the pictures the equipment (pumps) not show in callout
plan view and callout have same view template
Callout View
Plan view
Solved by mehrdadjavaherihotmail_com. Go to Solution.
You'll need to upload the model please, or if that is not possible then screenshot the view settings, view template settings, view ranges etc and attach those please.
Scale can affect what shows up on callouts. What scale is the callout at?
It looks like you may have different view ranges. If they are the same, the view template may not be set to control everything.
Thanks all for your replies. I found the solution. In visibility setting(VG), imported categories, imports in families was off.
And THAT wasn't being controlled by the view template? Really?
