Revit MEP Forum
CAD import into section view
4 REPLIES 4
igoteseanu6NLUR
228 Views, 4 Replies
Good morning,
I'm trying to link some CAD drawings into a section view in Revit but I can't see them.
I can see them on the floor plans but not in the sections.
It's look like that a problem is with visibility/graphic overrides.
Thank you !!!
4 REPLIES 4
They might be beyond the clip plane of the section view.
Locate them on plan and move them into the range of the section.
Can you send me a printscreen please?
Thank you.
Firstly, make sure "orient to view" is set when inserting into section. This will make the cad drawing stand on edge.
Then in a plan view find the cad view. Here the cad view is on the left, the section is further to the right and facing the opposite way:
Unpin the cad view and move it into the extents of the section:
It will now be visible in the section view. Align it to floor levels and walls and then re-pin it.
In the plan you can hide the cad plans so that they don't appear as long lines.
Great thank you !!!
Forma Design Contest
Technology Administrators
