02:50 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've run into this lately in a 2018 project where duct and pipe components that typically would "break into" the pipe or duct now do not actually create a break. The object will size and locate as if it is inserted within the pipe/duct but does not actually break the pipe as it has in the past. These are families that we've been using for 4+ years and never had much of an issue but on this particular job they rarely work. Not sure if there is a known issue that would be limiting the function of these but incredibly time consuming to break pipe at each valve and reconnect.
Mike
